Any difference between C:\Shared\foo.exe and \\localhost\foo.exe?
stevenkan
Troubleshooting related to my other problem, but genericized as a general question.
Suppose I have:
C:\iERP90\iERP90_TEST\Server\
on a Server 2022 box named \\iERP90
shared as:
\\iERP90\iERP90_TEST\
where that directory contains ClientSetup.EXE
Is there any difference between running on the iERP90 box itself:
C:\iERP90\iERP90_TEST\Server\ClientSetup.EXE
and running on the same box itself:
\\iERP90\iERP90_TEST\ClientSetup.EXE
In the latter case does Windows say, "Oh, that's my own share, I'll treat it like a local file."
Or does Windows run it through whatever permissions and policies it has for a network share, despite it's actually local?
When I run it from the network share, it definitely launches slower than when I launch it locally, but when it's actually running I don't see any network traffic, other than typical "heartbeat" traffic:
This is via the Hyper-V Manager, not RDP, so there's no RDP traffic in there.
Thanks!
edit: fixed C:\ C:\
Andrewcw
It should run through permissions if it is accessing itself like a share.
So it follows whatever user or system permissions the program is running is running at accessing that share.
But I'm lost at the VM network traffic. The share is on the VM's "Local" drive so inside the VM there would be no network connection to access it's own share. It just follows the permission.
Reactions: stevenkan
stevenkan
The scale on the network graph is 100 Kbps. That's just background/heartbeat traffic. It didn't go up or down when the installer attempted to run. I had it displayed so I could check for new network traffic, and there was none.
andrewme
Senator
7,112
The point is, the graph cannot help answer your question. You're looking at a network adapter that connects to the outside world. If accessing an SMB/CIFS share on the current machine does go through the file-serving stack (and I'm pretty sure it does), you would not see network traffic going out to your local LAN, turning around, and coming back in. It's going to stay within the kernel / on Windows' equivalent of the "loopback" adapter (there might even be an optimization in the file-serving stack so it doesn't generate any TCP/IP socket traffic at all).
The graph would not look any different if Windows did treat the access as purely local and bypass the share permissions.
