Beginner's Network Tool Box
Rafaelse
Hello,
After many years only doing simple home and office network cabling I have started doing some more professional work, and while I have the basic tools like RJ45 crimp tool, a cheap cable tester, jacks, plugs and some other tools. I would like to make a proper Toolbox for work, currently mostly for installing network cabling and equipment like AP, Switches, DVR and IP cameras and I would like to ask for recommendations and suggestions on what would be your must have have tools.
Thanks to everyone in advance :)
Wheels Of Confusion
A Tone Generator And Tracer set is invaluable.
I'd call them absolutely essential.
Also keep some cable clips, coax stripper tool, crimp tool and decent ends, either a balun or a special purpose coax toner. I can't vouch for this specific kit but Jonard packs the essentials together here for a reasonable price. Used to use Jonard stuff professionally, it's a good brand. A properly tuned torque wrench is also nice, to keep you from angry-tightening those F-connectors. They're really not designed to be tightened past 30 inch-pounds.
I love the Stanley Six-Way in particular as the only everyday-carry screwdriver for this kind of stuff. It has two sizes each of Philips and Slotted bits, as well as 1/4" and 5/16" hex drivers, and the notches in the grip will even work on stubborn wingnuts. This fits any screw you're likely to encounter and you don't have to juggle a dozen different single-ended bits. If the driver bits were magnetized it would be flawless. If you don't need the wingnut compatibility then virtually any other brand will work.
Screw-down cable clips are great, and the ones for RGU-6 coax also work fine for Cat5e-etc. The secret to clipping (or even tacking/"stapling" if you must) is that the cable has to be able to slide freely within the clip, not pinned and immobilized. Don't crush your cables! If you can't stand at the far end of a straight run and easily pull the unterminated cable through all the clips, you're doing it wrong.
A drill and 1/4" hex driver (with integrated magnet!) are pretty much required if you want to get a job done before midnight. Springing for a decent drill with a built-in hammer function can save you the cost of having to buy a separate drill (for boring), impact driver (for fastening), and rotary hammer (for light masonry drilling).
Rafaelse
Thanks, I'll have to look in to how to use these, these are part of the cable tester kit I have but haven't used yet.
@Wheels Of Confusion
Never though of using a tuned torque wrench, great idea, and that Stanley six-way will keep my tool belt lighter and I'll magnetize the driver bits. I've been looking at a Milwaukee drill kit, seems to cover the basics.
I've been looking at one of those IP Camera tester thing from Aliexpress, seems very handy to check where the camera is looking at while installing.
Wheels Of Confusion
Also, get more than one tone generator. That way you can tone out more than one line or pair at once, and be able to tell one from another. You can even mix and match brands of tone generator so that they sound distinct by default.
I like the Pro 3000 generator/probe kit for balanced pairs as a simple solution, but only because they were provided on my job. We were also issued a tone probe with a filter setting to help reduce noise (like the 60Hz tone of electrical service), but those tend to be more expensive. We also used a Greenlee kit very much like this one and it was just as good.
If you already have a set that works for you, maybe just pick a second tone generator to go with it.
Rafaelse
Thanks, I'll pick another one later, currently working with a low budget and want to work in getting all the essentials.
Reactions: makimaki
Deleted member 46272
If you're going beyong just pulling cable, then I really recommend a LinkSprinter 300. It fires up an ad-hoc WiFi network that gives you access to it's built-in webpage. Being able to plug it in and have it tell me which switchport a cable goes to, see PoE status, and test connectivity to the gateway and the internet within about 20 seconds is invaluable. It does basic TDR cable testing as well, which is also very useful. 2 x AA Batteries last for several weeks of heavy usage and it's very small, light, and indestructible. Amazing device.
I'm not a cable installer, but I do need to tone cables occasionally. I like the Intellitone Pro 200 because it lets you tone cables that are still plugged into a live device, and the tone generator has indicator lights letting you know if the cable is live or not. It has a very sensitive "digital" toner but can also be used as an analog toner, and it has a built-in cable continuity tester which is great for basic validation.
I don't pull cable on a regular basis, but I've had to do it dozens of times and I'm managing cabling projects all the time (~10-15 per year) as part of my job.
I'd really recommend:
https://www.specialized.net/catalog/pro ... gory/3504/
There are cheaper metal ones, but those are REALLY dangerous as there is often wiring with exposed terminals hiding in spaces that you'll probably end up poking your head into.
glow-in-the-dark fish tape:
https://www.kleintools.com/catalog/fish ... pe-20-foot
(really useful for finding the other end of mystery conduit)
Absolutely get a non-contact voltage tester to keep yourself safe:
https://www.amazon.com/Non-Contact-Volt ... DF9K1SJHUE
... and if you will be doing equipment installs as well, then an outlet tester may be handy as well.
Last but not least, figure out how you will be organizing your materials and tools. Start looking at modular storage systems, such as:
https://www.homedepot.com/b/Tools-Tool- ... 1vZc22aZzv
Don't invest a ton up front, but work for a while with what you have but think about what use cases you run into and what the pain points as, then start building a system around that. What you will need will depend a LOT on what type of work you end up doing, if you are rural and can park nearby or in a city and need to roll tools in from a garage, if you have a pickup, van , or working out of a sedan, etc.
I'd be wary about leaving tools or materials in any vehicle. Vehicle burglaries have gone through the roof in some places in the US, and thieves will target anything that looks like a working vehicle if it looks like it may have tools inside. I'd suggest insuring your tools - most basic vehicle policies will NOT cover those or have very limited coverage.
Rafaelse
Thanks for even more great suggestions, I didn't know there where glow in the dark fish tape, that would've been very useful last year when I had to redo the network, audio and video cabling from a client.
About the punch tool, I have a basic one, somewhere, I think? :confused:
And those linksprinter and linkrunner sound interesting, I'll have a look.
And about organizing stuff I'll take those seriously, right now I'm starting with just a couple of tool bags. Hope this goes well and I'll have to get one of those nice tool boxes.
Right now I've been working mostly on residential and small government office, so mostly in the city, since I'm in Mexico I have to work on a small budget, and I'll have to add the import costs for some tools that aren't easily found around here, but if these make the job easier it will be worth it. Thanks.
Wheels Of Confusion
I probably can't help much for organization, it was never my strong suit. But when I was a tech I had an "inside bag" and an "outside bag." They were just plain canvas totes.
The "outside bag" was for stuff like masonry bits, cable clips, silicone sealant, grounding wire and lugs, closures, mounting screws, conduit cutters, conduit brackets, grommets, telescoping wire grabbers, etc. Plus some PPE for doing work in a crawlspace or unfinished basement. My job involved running cable from the roadside to the building, so maybe that won't be part of your work. The idea was I'd do the outside work necessary to hook up a customer's building with this, then take it back to the truck and swap it for the inside bag to do the interior work.
The "inside bag" had stuff for interior wiring like keystones, jacks, surface-mount closures, punchdown tools, drywall saw, Cat5 and coax crimpers, Cat5 tips and Coax F-connectors, smaller mounting screws, some stiff wire (usually trimmed grounding wire) in like 30cm lengths for ad-hoc wire fishing, a dust brush and dust pan, stuff like that. But I didn't do a lot of work inside smart panels or real wiring closets, I was mostly going from the outside demarcation point to the modem location and maybe a few wires for IP TV. Any scraps like wire strippings or dust from drilling got swept up into one of my discarded plastic bags (the CPE came wrapped in these) and rolled up, tossed into my bag, and taken out at the end of the job to dump out back at the garage.
I had a second "inside bag" just for carrying CPE (modems, IPTV receivers, remote controls, printed channel guides, etc.) Each bag was cleaned out and re-stocked at the end of each day so I could just grab-and-go when on a job.
On my toolbelt I had my no-contact voltage detector, tone probe, tone generators (the test leads made a nice loop to hang them from), wire cutters, Kevlar snips, a real impact punchdown tool and puck, a cheap stripping/punchdown tool as a backup, combination needle-nose and butt-connector crimper pliers, electrical tape, screwdriver, plus the various drivers and can wrenches I needed to access our closures. Whether doing inside or outside work, I would always need at least some of this stuff handy. Also kept a small bag each of F-connectors, Cat5 tips, and butt connectors just in case. We had small plastic high-visibility tags for labeling a customer's service lines, so I carried a bunch of those as well as an all-weather Sharpie in my pockets. They could probably have been in a compartment on my belt if I had more room, though.
You probably won't be working aloft at utility poles but I had a special canvas bucket/bag just for that, which would clip to my safety belt. I had the hardware for hanging "drop" (the cable that carries service from a pole to a building) in there and I'd also chuck in a few essentials from my tool belt like the voltage detector.
Reactions: m0nckywrench
Well, you sound more organized than a great many cabling techs I've dealt with, so your name doesn't check out :). Some of the really bad examples I've dealt with had horrible trainwrecks in their van and they spent as much time digging for crap as they spent working, would need to pull have of their stuff out and dump them in piles around the van to get to tools or equipment that was buried or to just find things. They would end up with lost or broken tools or materials and waste even more time working around those obstacles. It wasn't a single isolated example and some had been in the industry for many years (hence the piles of crap in the van that never got cleaned out).
One of my favorite techs, who's been in the industry for at least 25 years, drives a Honda Accord with a roof rack to sites 90% of the time and is incredibly well organized and efficient and manages to carry everything he needs to including ladders, plywood, conduit, etc without having to bother with a van (saves him tons of gas), while others drive a Chevy Express and never seem to have room or can find anything.
Staying organized keeps you efficient, and staying efficient earns you more money. Even if you are paid by the hour, any competent foreman or PM wold notice the wasted time and wouldn't call that kind of person back for a second job.
Wheels Of Confusion
Vehicles were a different story. My work trucks tended to be an absolute wreck, but only AFTER they downsized us from the Chevy E-3500 to the Transit Connects or the covered pickups. Getting a little off-topic so I'll spoil this rant:
The Chevy had real tool chests with sliding drawers, shelves, and racks with enough room for all the transport type (satellite, copperline, and fiber optic) jobs we had to work. That's despite the huge LNG tank they installed in it for the conversion (which reduced the range to about 150 miles, and there were only about 4 stations to fill it at in the surrounding 5 counties). It was great, especially since I could access it from the rear passenger's side or the back and could stand up inside it if need be. A real joy to use, in hindsight. Always loved working out of that one, but it was not to last. I was assigned to a new garage after about a year and the van went back.
The converted pickups were old Ford F-250s with the usual tops+cabinets added to the bed and the locking swing-open doors in back. The bed had zero guides or shelving to keep all our boxes of cable, satellite dishes, etc. organized so everything tended to fall towards the cab over time and it required the "take half the stuff out" approach as often as not. Not being able to just walk in from the short side, or even stand up in it and peruse the shelves my Chevy van had, really hurt efficiency. The side cabinets that ran the length of the bed could only be accessed from outside, which sucked in the rain. But at least they were usually big enough to hold all our boxes of CPE and smaller consumables.
The Transit Connect (yes, the minivan version) was more organized than the pickup, but incredibly cramped for the 3 different transport types we had to work with. Especially the center of the cargo area was so narrow you couldn't access more than one type of cable (fiber or copper or coax) at a time, again requiring the ol' dump-and-rummage to access some things. In fact the reel stands they issued for direct bury 2-pair drop wouldn't fit between the rows, so I had to disassemble the reel and fold up the stand to stow it then re-assemble it when I needed to run drop. I honestly don't know how some people made it work, I could only do it by neglecting the bulky satellite dishes until I was assigned a job for it (fortunately those were first-of-the-morning types so I could just pack it at the garage before leaving). Fucking awful.
The kicker is that the regional, legacy satellite contract shop who was allowed to wear our branding and get the majority of our satellite install and repair jobs all got full-sized Transits to work from. :mad: Our company knew for years that our jobs were going to encompass the satellite business as well as fiber optic in addition to the old copper stuff, but they still ordered a whole fleet of the undersized Connects. Just one of many bad decisions the company became known for in recent years.
But yes, a workable vehicle is essential for productivity. If you have a system where an old pickup works for you, great. No reason to change. Just make sure the vehicle is organized to give you quick access to anything you need and is easy to get into/out of.
Andrewcw
Ah low low budget is probably what draws you to doing Plugs instead of Jacks. You'll want an impact punch down tool with 110 blade and if you're in an old enough infastructure area a 66 blade. Usually the cheap ones come with the combo of both blades. So buy the cheap one if you don't have it. And if you eventually run into a jobs that really start to use them. Then buy the better one.
These might be still prevalent in your area https://en.wikipedia.org/wiki/66_block
The more modern 110 block just uses the same as Cat5 jacks.
But get some experience in punching down jacks on some Cat5 jacks. You can re-use jacks a few times before the wear out. And the joy of using jacks instead of plugs. Is they always have the color chart painted or a sticker on the jack showing you the two standards of where wires need to go. So you know as long as you follow A or B standards you won't have to worry about did the wire cross when i stuck all 8 wires into this plug before crimping.
While I don't do full-on cable pulls any more, I still have to troubleshoot/repair installed network lines occasionally. Here's what's in my toolkit:
--Philips and flathead screwdrivers
--Scissors
--Crimp tool, non-ratcheting
--Flush cutters
--Punch-down tool
--Bin full of keystones/RJ45 connectors
--Label maker (Brother P-touch fo lyfe yo)
--Cable toner
--Cable tester (99% of the time a simple one will do; if I get weird results then I'll pull out an analyzer, but this has been rare)
--NC voltage tester
--Good flashlight!
When actually pulling cable/installing wall jacks I'll add stuff like:
--Fish tape
--Fish poles/sticks (great for working above suspended ceilings)
--Drywall saw (or better yet, oscillating tool)
--Drill/drill bits (if working on masonry, then add a rotary hammer)
--Ladder
--Zip/vecro cable ties
--Pencil, Sharpie, masking tape
This is in addition to the consumables, of course (cable spools, wall boxes/mud rings, keystones, faceplates, patch panels, etc).
Xenocrates
I'm going to suggest a few oddball things, just based on my experience with (primarily industrial) networking. A shoulder mounted light, I like the Guardian Angel series, because I have to work around forklifts and in truck yards sometimes, but anything bright that will sit on your shoulder will do. I find headlamps are usually harder to work with in cabinets, since they start out higher.
A cable tester or switch that includes some feedback for cable length. Some of Microticks little switchs have them, otherwise, I use a Fluke Microscanner at work. Some of the semi-fancy ones on Amazon that do POE testing also include that. A length that doesn't match the physical will indicate a problem, typically with termination.
If you do any fiber work, a small handful of couplers, adapters, and a selection of bend-insensitive fiber patch cables, so that you can connect your known good test equipment when doing installs. Also a cleaning pen for fiber.
If you install the gear in comms racks, a cage nut tool and or rack-studs are really nice to have, but tend to be less common unless you're doing the whole build yourself.
USB-serial bridges, and appropriate console cables. Serial only consoles may be going away, but they still exist in places, and for the cost and size, having them avaialble to deal with legacy equipment is good.
Also, if you're going to have power tools, and don't already have some from a brand, pick one of the brands that has a 110V inverter, like Milwaukee, Ryobi, or Hart, so that you have a UPS-like option for bringing up wall powered equipment temporarily in an outage or in the field. They're smaller than extension cords, after all. Milwaukee also has some really neat powered fish tapes, which if you do industrial or long hauls in conduit, could be very nice.
Frennzy
Also, I recommend hard loopback units. SC, ST, and LC. This is a super quick way to determine if your provider is getting light to you. While you're at it, a small number of MMF and SMF SPF and SPF+ adapters for 1G/10G. Maybe even a 1/10GBaseT version. While you're at that, maybe one active and one passive DAC.
[quoted]USB-serial bridges, and appropriate console cables.[/quote]
Yes, and TESTED ones. Make sure your USB-serial device actually works on various equipment. Also, Null modem adapter(s). Plan on losing/leaving behind/destroying all of these on a semi-regular basis.
Rafaelse
Ah low low budget is probably what draws you to doing Plugs instead of Jacks. You'll want an impact punch down tool with 110 blade and if you're in an old enough infrastructure area a 66 blade. Usually the cheap ones come with the combo of both blades. So buy the cheap one if you don't have it. And if you eventually run into a jobs that really start to use them. Then buy the better one.
Found my punch tool, just was misplaced, I only terminate with plugs if it's a simple home install, for place where there is a rack I always punch jacks in the patch panel, and use patch cable to connect the equipment to the switch.
the 66 block remind me of the telephone system from the municipal government that they wanted to move the extensions to the office in the new building. But the cabling was fully exposed on the roof, unlabeled, undocumented, unprotected, hold in place with some nails and bricks, for the last 23 years, on a low budget. NOPE, not gonna touch that and give a warranty, I suggested that they migrate to an IP PBX with IP Phones, made the justification and convinced them to migrate, and didn't get the contract because the manager had a "friend" who could do it cheaper (probably meaning they got a piece of the deal). :facepalm:
@Frennzy
Those USB serial adapters, haven't used them in a while, have a couple, how troublesome was when the company behind the chips decided to update their drivers to block all the cloned chips. So far I have managed to avoid handling the configuration on most equipment I didn't install, always ask to be given the details of configuration of any equipment they ask installed in any existing network from the IT department.
Rafaelse
Has anyone used one of this IP Cam testers or something like this?
https://www.aliexpress.com/item/3285809 ... udzkS&mp=1
ordering one of these: TI-HT9652C
Won a contract to install 50 cameras on a bus station, and since I'm gonna have to go up and down the ladder many times for every camera I would like check the camera view and cable testing from the beginning and not until the whole network cabling it's done.
Andrewcw
So other then the BNC connector to test a NON-IP camera out. Mostly everything on there is redundant to your toolbox.
If your cable is good from the network testing equipment. Your camera will be good. And to test Angle. You're better off with any generic tablet that has the software the connects to the NVR system of the location you are installing for.
As in before you pull the wire. You take the time to connect the cameras to the NVR. Make sure they all work. Document MAC addresses of the items you are installing. Make sure your viewing device works. Then go up and do the cabling/install.
stevenkan
That looks, conceptually, like a great gadget! Portable POE and wireless backhaul? Yes, please.
I can't tell you how many times this would have made my trail camera installations 100x easier. The only thing it's lacking is a WiFi antenna port for when you're almost out of range. But I doubt anyone makes stuff with that. Similar products available on amazon, if you're worried about buying from aliexpress.
This is no substitute for a professional cable tester costing $thousands, but for $200 it's a nifty little gadget:
https://pockethernet.com
I really like mine, despite using it only for home use and light office troubleshooting.
It's substantially similar to the Linksprinter 300, but the Linksprinter is MUCH smaller, lighter, faster, and the batteries last longer and it takes 2 x AAA batteries that are quick to swap if they run out (no need to wait for a charge). It also does NOT need an app to use because it just creates an ad-hoc access point and the dashboard is it's built-in web page. No app to break or become out-dated if the vendor stops supporting it.
I played with both a few years back, and the Linksprinter is totally worth the price difference, in my opinion, if you will be using it heavily for work. For light, occasional usage the Pocket Ethernet is probably OK.
stevenkan
Unless the punchdown block has an ambiguously placed sticker:
My networking contractor started at position 24, and started with Blue/White "because it starts with white." :facepalm:
They did all 24 positions wrong, and had to rip them out later. The supervisor was so pissed he brought a new patch panel with unambiguous labeling.
If only he'd looked at #20, first.
stevenkan
I'll redirect this part of the conversation to my other thread about networking contractors, so as not to hijack this thread about the Beginner's Network Tool Box.
To get this back on topic, I used the TDR feature of the Pockethernet to determine that one of the bad runs was a bad termination in the wiring closet and not at the wall jack, which was very helpful.
I've found that I very rarely need to dig out the Fluke to test a cable run. The vast majority of cable failures I've seen have been due to bad terminations, which my cheap $30 Klein tester can easily show. Beyond that, our switches (Juniper EX series) have built-in basic TDR testing capabilities, so finding mid-run cable faults can be done from the comfort of my desk. But the Pockethernet does LLDP, so I might pick one up anyway since that would make identifying mislabeled wall jacks much quicker.
stevenkan
Nice! I had no idea these existed.
Rafaelse
There is a version with external wifi antennas and optical tester, and some other features, price goes up quickly though. Might be worthy when I need to work with fiber.
@Andrewcw
Already documenting install procedures and equipment installation: S/N, MAC addresses, IP Config, Passwords (non default ones that will be changed be the admin/owner), switch ports, network map/schematic/blueprint, etc. so the admin can take over with ease. Most of the time the configuration is as close to default as posible since they are going to handle this. This has saved me a lot of work a couple of times when doing some service/upgrades/warranty work.
I use the TDR functionality on the Linksprinter all the time. It's great when you need to figure out if the issue is at the jack at the "far" end (most common), at the patch panel (less common), or somewhere in the middle, which can happen due to another cable pull snagging a line, rodent damage, etc. My toner (Intellitone Pro 200) has a built-in continuity test that's useful as well, but it's more for finding and validating that you have the right cable. (incidentally, I bought the Intellitone for about $110-120 a few years ago, and I'm shocked that it's now selling for $270-$300!! WTH!!! :eek: :scared: )
The newegg listing has a comprehensive collection of screenshots from the device web page if you scroll down. Ignore the pictures at the top of the listing.
https://www.newegg.com/netscout-systems ... 008M-00009
