Help Finding a GPO Option?
antiwraith
I'm trying to track down a GPO setting, specifically the setting for "Turn Off Spotlight Collection on Desktop". It supposed to be under "User Configuration\Policies\Administrative Templates\Windows Components\Cloud Content\Turn off Spotlight collection on Desktop" but it isn't. I'm running the most recent ADMX files for Windows 11 / Server 2022. When I look in the Cloud Content folder with group policy that setting just isn't there.
Any ideas?
dodexahedron
You likely need to download the most recent admx templates for the versions of Windows that you support, and deploy them to your domain controllers' policy store.
Here are the Windows 11 22H2 admx templates: https://www.microsoft.com/en-us/download/details.aspx?id=104593
Here is how to deploy them to the policy store: https://learn.microsoft.com/en-US/t.../group-policy/create-and-manage-central-store
Note: This will cause the group policy management console to be slower when opening the Administrative Templates folders, if you don't prune it down to just the template files you actually need/want to use. You can use nearly any combination of the included templates, as most are independent. There are a few that supposedly depend on each other, but I couldn't tell you which those are. Also, if you install ALL of them, rather than just what you need, it can cause at least the first GP refresh for any system in the domain to be slow, while it downloads all the templates and compiles them.
Also note that you need to wait for the files to replicate to all domain controllers before creating/modifying group policies that use the new templates. Otherwise, you may have various group policy processing failures until they are fully replicated. Unless you have an AD topology that has remote sites that are more than 1-2 hops away from the DC you install them on, this should be ready to go in under an hour, so just install them, wait an hour, and then have at it.
You can even make your own templates to control literally any registry setting you like. Take a look at the XML of an official one and you can figure it out pretty easily. Probably best to stick to official templates, though, if you don't have a reason not to.
antiwraith
Yeah, I had done all of that. No Joy.
Then I figured out my problem. I'll post it in here in case someone else comes down with a case The Stupids like I did. The setting was under User Configuration not Computer configuration.:\
Reactions: SplatMan_DK
dodexahedron
Ha. Have been there before. Searching for hours, totally tunnel visioned... Then find it while doing something else, and nearly give myself a concussion from facepalming so hard.
dodexahedron
Followup ADMX question...
Are you all keeping all ADMX files from all active OSes in the central store until those OSes are removed from AD, or are you only keeping the latest editions? IE. If you have Win10-21H1 ADMX installed and go to install Win10-21H2, do you keep the original one as well?
A more recent one basically supersedes the older ones. Old items are rarely actually removed. Settings that are not supported on an earlier version of windows simply won't have any effect. They all translate to registry entries, so if the system doesn't understand one, it just won't do anything.
You can diff the files if you really want to, to see what has changed from version to version. They're just XML files (both the admx and adml files).
dodexahedron
Whatever is in the central policy store is whatever is in the central policy store and will be distributed via DFS-R to other domain controllers, and domain members will get them from there (\\domain.tld\SYSVOL\domain.tld\Policies\PolicyDefinitions by default).
If you delete an admx (be sure to delete its associated adml files too), it is gone, and its settings won't even be shown to you in the GPO editor MMC any more.
That said, the admx isn't where the actual Windows settings they correspond to come from. They are all just registry keys/values, and group policy is just an XML configuration system that distributes a bunch of instructions to each system to apply whatever registry settings correspond to that policy. The registry options are just part of windows. The only reason we have to get updated admx files is because windows itself will have new features or removed features, with each new version. Even some Linux systems can understand certain built-in Windows group policy settings and there are more specific group policy templates available out there (or you could make your own) that work with some Linux/Mac distros or software.
You could delete them all if you wanted and have literally nothing available to you in the "administrative templates" section of the GPO editor, and pretty darn quick group policy processing, but you'd be limited to things that can be controlled without using that whole tree of stuff, or manual registry entries in your GPO.
