NUC machines and distributed computing performance
Been away a long time (obviously) doing other things.
The internet isn't what it used to be to find out basic stuff.
I am curious about the NUC machines but wonder about their performance. There's a million of them out there, full of no-name sites touting them. Some are full of dirt cheap N95, N100 stuff and I am middling interested in those. Far more interesting is stuff with an i5 or i7 in it (and their AMD equivalents).
But, I've also read a handful of suggestions that heat limits their performance and so it isn't just a matter of looking up CPU specs. Are these just another flat earther website, or is it a real issue?
I figure if anyone in my circle still knows about sustained performance, it is you guys.
Does anyone here know what the real story is? I have a use case that might crater if the NUC in question throttles back for thermal reasons.
continuum
Celeron-based NUC's (and equivalent uSFF boxes from HP, Dell, Lenovo, etc. with the same CPU) are all pretty low power draw so they should not have cooling issues that might limit performance. You will probably see them hitting designed power limits but that's normal behaviour as designed as necessary as opposed to signs of a thermal issue. (desktops often do not enforce power limits, for perspective)
If you are looking at traditional mainstream laptop line-up NUCs based on Intel Core or AMD Ryzen processors, then yes, you might see some thermal limitations.
i..e: Alder Lake and Raptor Lake:
https://www.anandtech.com/show/1872...-canyon-kits-review-alder-lake-in-ucff-avatar
https://www.anandtech.com/show/1879...n-review-raptor-lake-brings-incremental-gains
vs. Jasper Lake:
https://www.anandtech.com/show/1748...ucff-pcs-review-desktop-jasper-lake-impresses
GeneralFailureDriveA
"We review the top 17 ways to find out basic stuff on the internet [2023] Number 14 will shock you!"
No. It most assuredly is not.
They are best suited to desktop use, small periods of burst performance within the thermal inertia of the system, and are not well suited to the sustained performance demands of compute. Yet, with some possible creativity, they can often be made to work.
It is a real issue. A typical NUC will throttle and significantly limit performance in almost all cases. However, there are ways to mitigate it. First, most have various settings of thermal behavior in the firmware configuration utility: You must set performance. This ramps fans rapidly and loudly, but will maintain better performance.
Beyond this, if you are free to modify them, consider some of the additional heatsink modifications one may find on Reddit and other places. Simply, you remove the case, cut additional holes, and mount a standard heat pipe based heatsink either in place of the stock heatsink fan combination, or, similarly effective, on top of the stock heatsink. Place the auxiliary heatsink on top of the CPU, directly on top of the heat pipe, with thermal grease. With good fan flow, this will pull additional heat out of the system, allowing better sustained performance.
But, simply, if maximum performance is a concern, a typical desktop chassis and heatsink will radically outperform a NUC. They are not built for sustained high performance compute. Or, at least, older ones are not. I cannot speak to newer ones.
Thank you all. This is the most succinct, but all the answers were exactly what I was looking for.
The work in question will be sustained, not forever, but in units of minutes to tens of minutes of intensive computing and then go away. Sounds like it will run long enough to throttle, which is exactly what I don't want. So, sounds like the old fashioned SFF "true" desktop (the kind that is small, but still can put a monitor on top of it) is the smallest I should be looking it and old fashioned mini-towers and towers are still competitive for this kind of thing.
Yes. Tens of minutes of sustained compute on a standard NUC platform will throttle in any reasonable conditions. It may not be massive throttling depending on performance and fan settings, but it will not be maximum sustained performance.
I cannot speak to the small "monitor on top" thin client size desktops, but I expect they suffer similarly.
A midtower with a good heatpipe based heatsink and reasonable fans should run at maximum performance without limits, until you get into exceedingly high power chips.
Yet, does a 10% throttle reduction in speed matter for your workloads if you are looking at older hardware?
Neill78
I have a cheapo NUC-like i3 jobby and in Windows 10 the fan will spin up within 10 seconds of any hard work, and it will throttle within a minute. I imagine an i7 would just basically be fan-on all the time.
Windows 11 demonstrates less overall fan activity and gives more headroom before throttling.
ChromeOS was even better but will still start throttling in far less than 10 minutes. And I'm guessing that ChromeOS isn't going to be useful for your processing jobs.
The little boxes and their tiny fans just aren't meant for intense, sustained processing. They're not even that good as media servers for occasional transcoding.
