I just moved into a new house and have 2 UniFi APs installed. A U7 Pro Max and U7 Pro. It's a split level house, kind of in a T shape. The horizontal bar of the T is the lower level where I have the APs installed on opposite ends, wall mounted high (the ceiling is angled into a point on both ends, not flat). The upper level with 3 bedrooms is on the vertical bar of the T, which is also where my office is.
Downstairs I have excellent signal strength in every corner of the house. Upstairs, particularly in my office where I need it the most, signal strength is a lot weaker.
I installed the Wifiman App, but apparently to do a full scan I need to buy a $99 Wifiman Wizard device (used to be able to be done directly from the phone?).
I'm wondering if I should move one of the APs more towards the center of the house, or buy a third AP (like a U7 Lite) that I'd ceiling mount upstairs. Mostly care for work and stuff, videoconferencing and just generally having a snappy connection.
What would be the right approach here?
