Hi everyone,
I am stumped at this problem. I have 2 customers. Both use a FritzBox (popular german router) as their router and both have DrayTek WLAN Access Points connected via Ethernet. The APs are configured in bridge mode so the wireless clients get an IP via DHCP from the router. Clients (MacBooks, iPhones, etc.) do all connect fine and have very good reception. After a while (sometimes only minutes) the wireless clients can not load websites completely. It will take minutes to load and often miss many images. This is apparent on Facebook or using Apple Maps where some tiles will not load at all or very slowly.
The internet connection is not the problem, Ethernet always works fine. Both customers even have different models of the router and different connection types (VDSL and cable) as well as different models of DrayTek VigorAPs.
If we use the built-in WLAN of the router all is fine as is the case with Ethernet. But we need separate APs due to the locations.
DrayTek support told me to disable Airtime Fairness which did not help. Anything I can try before setting them up in routing mode (separate IP range and Double-NAT)?
