how to connect to a lan over the internet !
maxx
I know this:
I have to use TCP/IP both places.
Then i need som help coz.
I have a lan @ home and i want that lan to have access to the lan across the internet.
How do i connect the 2 lan's with out letting everyone on the internet have access to both lan's
Please help me. Coz If i make this work i can get rid of my ISDN link to work and get ADSL instead.
MAXX
reboot
Luc
Or you can spend two times $50.00 instead of many hundreds of $$$$ for Win2K Server at the two ends, and buy IPRoute which supports IPSec., interoperable with IPSec from Linux, and runs on a 386Sx/16 with 1 (one) MB of RAM, and does NAT as well if you need it for your local LAN.... It even comes with a 286 executable if you want to reuse an old 286/20 (which is about as fast as a 386/25 in DOS!). See some comments and pointers here:
http://www.insyte.com/iproute.html
http://www.connactivity.com/~esj/ipr/ipr.html
http://projects.shn.nu/homenetwork/iproute/
Of course, you can do it for free using Linux, but I do not know how, and $100.00 is a small price to pay to stay within familiar territory (DOS) and get tech support as needed, specially for a one time job...
You need NT? Hmm. Strangley enough, NT doesn't play any part in my companies VPN.
If you have a router of some sort (ISDN/Cable/DSL), Lucent has a few models of routers and have VPN client software for them. You could also go the firewall/VPN appliance and connect the two firewalls or connect using VPN client software.
Nevertheless, NT is not a pre-requisite.
